Hi,
Apologies for writing in English.
I have heard of hear pump that generates hot water for house, heat for radiators and recuperation system in one - flexit wh4.
I am looking to buy one but there is no one in Poland that has it.
Flexit is Norwegian brand, and apparently wh4 is being sold already in Czechia and Slovakia.
Have you heard of it? Is it any good heat pump?
Thank you
Also, it's worth to mention that heat pump runs with co2 gas instead of typical refrigerant gas. Co2 heats up to 120 degrees Celsius, hot water tank can be heated up to 65 degrees C. Heat pump can run on classic radiators.
very interesting option.
@bednim Hello.
EcoNordic is primary for floor heating. Because it can give a temperature of 50 ° C, it can also be connected to radiators.
You can chceck the official Flexit.eu webpage for central Eurpe. Here you can find contact to the Polish market.
I believe I helped you.
If there are any questions, let me know.
