Vyhody ZEON voci uz exitujucim rieseniam
Dobry den, nakolko cely portal modrastrecha je aj o "urob si sam" rad by som sa spytal aka je vyhoda samotneho riesenia ZEON oproti uz existujucim DYI projektom ako je napr. Cayenne, resp. konk implementacia Cayennu: http://community.mydevices.com/t/jiot... V tomto projekte, ktory som navrhol su pripojene (verim, ze kazdy bude vediet prelozit dany zoznam): ED every marathone starts with single step and every IoT project starts with connecting the single LED so as mine. HW button simple HW button which can be used in Policies as input signal (it uses interrupt of RPI). Motion PIR sensor once again no magic here. What worth to mentioned is, the PIR sensor uses RPI interrupts which can be easily and in real time used in jIoT policies. Temperature sensor DS18B20 simple 1 wire temperature sensor connected to RPI. LDR light sensor as ability to measure sunshine and darkness simple LDR and Capacitor is connected. Light Strip RGB led strip which support to change color and brightness. Actions like dimming (out|in) are hard coded to LED strip driver. BlueTooth sensor internal RPI3 bluetooth module is used to track home activity of the person. Based on this we can build policy which are coupled with presence of the individual people. IP Speed Checker this "checker" simple ping given IP and presents its avarage speed value to the Cayenne cloud. IP availability very simillar checker as previous one, the returned value is just "up" or "down". PC availability of the PC. Currently written driver defines basic actions such as "on" and "off" Music Player we can track if Music is playing or not. There is possibility also to start or stop Music. Navyse dany projekt umoznuje vytvarat tzv. Policy, kde si uzivatel sam definuje svoje Spustace a Akcie. Samotna cena je minimalna nakolko Raspberry PI 3 stoji cca 60e a samotne suciastky su ozaj velmi lacne (najdrahsi je LED RGB pas). Je jasne ze ku danemu projektu je mozne navyse pripojit takmer cokolvek (PC, TV, Zaluzie...) Chcel by som sa teda spytat, aku vidite vyhodu samotneho ZEON oproti napr. takemuto rieseniu. PS: ak by mal niekto otazku ku samotnemu Cayenne projektu jIoT kludne sa pytajte :) PS: prikladam foto s dashboardu. Y
Podporuje toto riesenie aj M2M pripojenie IoT? Ide mi o nezavislost od Wifi internetu. Ja v zasade nemam problem s akymkolvek riesenim ale nech uz je univerzalne a ak mam mat veci pod kontrolou nech nemusim mat 4 kontrolne weby pre spravu bytu, alarmu v aute, chaty bazenu atd...
@ms_ Dobrý deň, riešenie, ktoré popisujete je presne pre domácich „kutilov“ a aspoň mierne zdatných elektrotechnikov, ktorí si vedia poskladať riešenie inteligentnej domácnosti sami. Raspberry pi 3 je malý počítač, ktorý sa dá konfigurovať v zásade ako chcete pridávaním rôznych modulov, ktoré uvádzate. Je to fajn „hračka“, ale určite nie pre každého. ZEON je užívateľsky jednoduché a pripravené riešenie bez nutnosti zasahovania do HW, resp. SW. Všetko je už prednastavené a určené k priamemu používaniu. Samozrejme, dá sa rozšíriť aj o ďalšie senzory a zariadenia, ktoré plánujeme do v blízkej budúcnosti. V tom je tá jednoduchosť, ktorú dnes drvivá väčšina spotrebiteľov vyhľadáva. A ak sa môžem opýtať, vami navrhnuté riešenie idete aj realizovať? Prajem vám pekný deň.
Takychto rieseni je dost uz som tu pisal do inych diskusii. Pouzivam DIY riesenie pomocou Rpi3 a serveru openhab,je to zlozitejsie treba sa vyznat v elektrotechnike trosku aby ste si vedeli co to zapojit sam. Dalsia moznost je sonoff ( http://sonoff.itead.cc/en/ ) cinska verzia uz hotovych wifi zariadeni na ovladanie zariadeni v domacnost vratanie aplikacie. Ziadny najom a ceny zariadeni su na prijatelnej urovni. Napriklad dialkovo ovladana zastrcka za asi 12€
co to je? navari to obed za mna ? :D neviem, asi som uz stary, kedysi ma IT bavilo (nie je to preklep za IoT), ale dnes neviem co by som nechal na automatiku, ak by to nebolo pranie, co IoT celkom urcite nezvladne, ani varenie nie, myslim ze ani upratovanie, aj ked par nespratnych vysavacov sa o to snazi (ale aspon hrubu spinu daju, co je asi vyhoda, v minimalistickej domacnosti, kden ie su prekazky), ale co ine ? mozno klimu spustia, ako som ju dnes fyzicky 1 tlacitkom zapol ja. Ale aj tak neviem, ci IoT vyciti aj moju naladu, kedze niekedy je pre mna 26C vela a niekedy malo - to by som musel mat v zaludku senzor, aby to prepocital. Zaluzie? Nemam na ne peniaze, zatial, robil som okna tak, aby tienili same seba. Ale ano, toto moze byt. Osvetlenie ? Tiez ho pouzivam naladovo. Kurenie? Naladove, ale mozno pomoze pri meniacej sa RV a teplote, resp nastavi kurenie+rekuperaciu nech to udrzuje vzdy v idealnom pomere. Zamykanie dveri? Toto preferujem robit sam. Bojler? Mam dost nepravidelny zivot, neexistuje vzorcec. Bojler sa moj zivot nemoze naucit. Ale mam otazku k teme - dokaze niekto DIY alebo hotove riesenie, aby som telefonatom, alebo SMS zapol nejake zaraidenie ? Staci mi uplne primitivny sputac prudu do obvodu, ako keby zapnem tlacitko. Nasiel som nejake hotove riesenia, ale ceny okolo 60eur, tak ze ci sa to neda urobit nejak inak, napr NOKIA 3310 alebo iny lacny mobil, ktory ked prezvonim, zatial co ho budem prezvanat, by mi nejak pustal prud. Zvacsa by som to potreboval zapnut len na par sekund, a potrebujem absolutnu spolahlivost, preto ten telefonat namiesto internetu (ktory moze padnut v nevhodny moment). napr, zapnut radio na blizsie nespecifikovany a vzdy iny casovy usek, na dialku.
@petko234 neviem uprimne co myslis pojmom Machine 2 Machine? Neviem ako velmi si cital ten moj clanok na danom cayenne fore, ale ako som napisal "Basically whole logic of the program is moved to local RPI and Cayenne web is (ab)used just as a presentation layer". Teda samotna logika programu (policy etc) sa vykonava LOKALNE na danom RPI3. Takze ANO samotna funkcionalita je nazavisla od internetu - tak je navrhnuta celu architektura. Ako vsetko ma to vsak svoje ALE. Momentlane je ale cayenne web pouzity ako prezentacna vrstva (ono ak chces mat remote management, tak to inak nejde spravit - ver mi ze tlacit domaci server cez ssh tunnel nie je prave idealna vec, pretoze ti aj tak treba Internet server). Co je vsak dobra sprava, ze samotny cayenne chysta poskytovat tzv. server on premise a teda mozes to mat cele dome a nazavysle od Internetu. Co sa tyka tvojej poznamky, ze je vhodne mat 1 rozhranie pre spravu bytu atd.. naprosto suhlasim a presne na toto som zameral cely projekt. Mozes v podstate pripojit lubovolne zariadenie/lokalitu na dany web interface - ak si vsimnes tak si mozes spravit "zalozky" podla lokalit (ja tam mam zalozku "livingroom"). @79kiko - ano pravda je za takychto rieseni je kopa (Phillipse Hue, Xiami ma IoT, particle etc..) Bohuzial mne v nich vzdy nieco chybalo :) a to hlavne spravit si spravanie samotneho intelignetneho domu podla seba. A presne na tomto som sa zamereal v tomto projekte, v podstate to bude "platforma" ku ktorej si uzivatel pripoji co len chce a nastavi si spravenie vhladom na ine pripojene zariadenie :) Samozrejme ze casom budu len pribudat :) V podstate je moze pripojit cokolvek co vies obsluhovat "Python" jazykom - napr. tv, zaluzky, internet connection (fb, pocasie. IFTT) etc. Potom sa daju vytvarat super easy policy - napr. (mometalne mam taku nastavenu) -> "Ak pohyb dome a bluetooth nenajde moj telefon -->> spusti alarm a posli mi email" a pod. :) @ivan_zeon je pravdou, ze samotne riesenie v stave ako ste popisal a treba na to troska zdatnejsieho uzivatela, no na druhu stranu je nutne si uvedomit, ze spravit user friendly interface uz je tym poslednym krokom ( a podla mojho nazoru vhladom na danu funkcionalitu nie az tak narocnym). Nie som si isty ci vacsina uzivatelov hlada jednoduchost, alebo skorej moznost si nastavit spravavnie vlastneho domu podla svojich ocakavani. Ak som to teda spravne pochopil, tak ako vyhodu vidite najma uzivatelsku jednoduchost? Samozrejme, ze sa mozte spytat :) Samotne riesenie uz je realizovane a funkcne (je to popisane v danom angl. clanku). Netvorim dany projekt len preto aby ostal v "supliku". Mometalne pracujem na jeho prepojenim s facebookom (fb bot) a IFTTT :) Samozrejmostou je pre mna aj pridavanie dalsich zariadeni ako su napr. zaluzie atd. Pisanie uzivatelsky privetiveho rozhrania bude poslednym krokom - myslim, ze velmi jednoduchym nakolko ide o napisanie GUI ktore len zapise vysledok do .json formatu :)
@ms_ jeden rozdiel mi napadol. ked raz bude mat takmer kazdy tento ZEON, tak pride FIXNY poplatok od sudruhov. kedze ludia nebudu mat na vyber (Raspberry neovladaju), alebo prapodivny obycajny I/O vypinac (uz nebude dostupny, legalny), tak nebudu mat na vyber a nebudu riesit, bude to navane licencny poplatok za software, ktory kontroluje, dava pozor, ci inak monitoruje domacnost. je naivne si mysliet, ze vyrobca preda inteligentne zariadenie za jednorazovu cenu, ako je toho u napr rohlikoch. daleko vynosnejsie bude prenajom (Windows 10), alebo pevny poplatok (SPP,ZSE,BVS,PZP a ine). kedze na trhu nebude nic ine, bude to jednoduche. ak taky uz teda neexistuje... A kedze zijeme v EUROPE, je len otazkou casu, kedy budu normy, ze treba merat aj obsah CO2, kolko clovek generuje, a budu na to licencie, dane a poplatky, a podobne.. pretoze pride nie doba kamenna, zelezna, ci EPSkova, ale doba smartova. Ale trochu mimo temu :)
Neviem si zatial predstavit ako na chate pripojim moje zariadenie na toto riesenie ked tam nemam wifi internet ale iba mobilny signal. Ano mozem si ho tam priviest ale bude to chciet dalsie zariadenie a kvoli zapinaniu kurenia a kontrole teploty to je nevyhodne. Cize myslim tym naozajstne M2M a IoT. Zariadenie bude podobne ako vase komunikovat so servrom ale inou formou pripojenia, cez male pakety...
@ms_ @ivan_zeon takychto rieseni na spravu, sledovanie a riadenie domacnosti je vela .... napriklad Broadlink ma plne funkcne veci spravovane v jednej aplikacii za zlomok ceny
@petko234 problem pevneho internetu je, ak vypadne elektrina, internet nefunguje, pokial nema zalozny zdroj.
@dusantt no asi ti IoT v dohladnej dobe nenavari, ale mysliim, ze kavu by mohol zvladnut :) :D Ja si prave myslim, ze ked dostanes moznosti si dane spravanie upravit podla seba tak sa daju nastavit uzitocne veci. (ak je tma a je pohyb smerom do kuchyne, tak zazni svetla) etc. Tiez si nemyslim, ze IoT je vseliek na vsetko, no verim ze pri rozumnej implementacii ti vie ulahcit "zopar" veci. Co sa tyka samotnych zaluzii a zamykani, nejde o to ze napr. to musi robit za teba, ale mat napr. moznost pozriet si na nete ci deti ozaj zamkli ked isli do skoly moze byt fajna vec. Detto s kurenim, ak buds mat informacie o tom ako bude zajtra vonka, ako je vnutry tak vies spravit ozaj mudre riadenia kurenia ;) Co sa tyka ku tvojej otazke, tak myslim, ze to nie je problem osobne by som si pozrel samotne Arduino a nejaky GSM shield ku nemu. Potom v "Ccku" spravis MQTT pripojenie a uz mozes byt ci uz na NETE alelbo bez MQTT kludne mozes len lokalne caro s tym robit :) Ku tvojmu druhemu postu: ano jednoznacne suhlasim, treba chapat, ze to niekto vyvyja a chce za to si nechat zaplatit absolutne to chapem. No pri dnesnej open konkurencii to moze byt dost neefektivny model. Napr. ak bude konkuretne OPEN riesenie so spravnou komunitou napr. na Githube tak neviem akoby tomu nejake firmy vedeli konkurovat (vid Ruby&Rails, Django...etc - myslim, ze neexistuje ani komercny produkt, ktory by sa snazil im konkurovat). @petko234 ako som pisal v predoslom prispevku, tu by bola mozna spravit si alebo vlastne rozhranie - napr. pripojenim displeja - cele riesneie je open, alebo potom dany on premisse server naistalovat na RPI ktore uz na chate mas.. :) Ale ono akby si chcel nieco "kde mas vsetko po dohladom" tak potom sa pripojeniu do internetu nevyhnes ;) Pre samotny projekt ako je ta chata mozno by bolo nieco lokalne lepsie, ale ako som napisal pre komplexnejsie riesnie pripojnie to netu by bolo vhodnejsie. @dusantt ono ked vypadne elektrina nebude ti fungovat ani samotne IoT riesnie ak nemas baterky :)) PS: co vravite na Big clown? Pohravam sa s myslienkou to preniest na tuto platformu :)
prave som si kupil GSM zasuvku za dvacku z aliexpres... celkom fajn cena za take nieco, presne na tvoje riesenie, podla mna, @petko234 ze mi to nenapadlo skor.. 1 SMS zapne a tiez dalsai SMS vypne zariadenie.. (a ked na to dam predlzovacku/rozdvojku, tak viac zariadeni ale naraz zaroven) @ms_ ak je tma a je pohyb smerom do kuchyne, tak zazni svetla - no podla toho, ako pre koho, ( :-D )ale ano, toto uznavam ze moze byt vyborne. kedysi ma to bavilo, ale to bol rok asi 1998-2002 a odvtedy som trochu zlenivel v technike, skoda no.. osobne by som sa len trochu obaval ohladom bezpecnosti, napr tie zamky, ked pojde skontrolovat, v akom su stave, - ale zas, ak sa fyzicky enda cez APK otvorit, tak potom OK, jedine ze by si zlodej nasiel pristup na zamok, a skontroloval,ci je zamknute alebo nie, ale zas, toto az taka extremna bezpecnostna hrozba nie je, skoro ziadna.. ale vseobecne ano,musim suhlasit, ze ak to clovek pouziva s rozumom, tak je to velmi velmi dobry sluha. len keby to nevolali smart :) to slovo fakt nerad pocujem... :D napr aj to kurenie, to moze jednak usetrit kopec penazi, a jednak zvysit komfort, a ked sa nad tym zamyslim, ked to uz budem riesit, tak uz bude podlaha hotova, a mozno aj budem byvat, to uz bude lepsia nalada na vychytavky, ako teraz, pri prieckach :D vdaka za inspiraciu, nebyt tejto temy, gsm zasuvku nekupim, zide sa mi to ako doplnok k alarmu :)
@dusantt presne ako si napisal - moze to by dobry sluha. Preto cely projekt je stavany stylom "pripoj si co potrebujes a nastav si to podla seba". Co sa tyka bezpecnosti, tak na tomto si dost zakladam (pracujem sam v oblasti informacnej bezpecnosti) tak viem o com hovorim. Mam v plane pouzivat MQTT cez TLS1.2 s vzajomnym overovanim certifikatov veci vlastnej PKI :) (to len tak na okraj). OT: Inak podla nicku sudim, ze si z TT? A ides v TT stavat (pretoze aj my sa chystame :D )?
@ms_ ano z TT, ale staviam daleko od TT, sice je to stale TT kraj :) TT mi bude chybat, pekne mestecko... take akurat :)
@dusantt ano gsm zasuvky poznam. No to je take znasilnovanie technilogie, ktora nie je to urcena a navyse s tym operatori maju problem kvoli zakonu o VTS. Co sice nebrani takemu pouzitiu ale je to naozaj zbytocne velke nekomfortne riesenie s nevyuzitym ptencialom. Preto sa na to pouzije M2M pripojenie a to je to co hladam ale zjavne je to este malo propagovane a malo zname.
@ms_ Dobrý deň, nemyslel som len užívateľský interface, ale aj jednoduchosť inštalácie riešenia, ktoré je pripravené na okamžité používanie bez potreby rozmýšľať nad parametrami senzorov a podobne.
@petko234 pozeral si aj to Arduino s nejakym GSM shieldom? Myslim, ze s tym by sa dalo vyhrat a splnalo by to tvoje poziadavky :) ivan_zeon: ano chapem, ze ste myslel cely proces, opat plati co som napisal, ze tento proces vymysliet (ak sa pouzivaju standardy (protokoly, procesy atd)) nieje az taky problem. Dolezite je pri tomto procese je za dane procesy pripajaju na modularne a vykone jadro :) (moj nazor) ALL: uvitali by ste v systeme TTS (test to speech) aj slovencinu? Teda bolo by fajn keby IoT na vas rozpravala po slovnesky? Popripade mozne spojenie so servicami ako je "Alexa" od amazonu, alebo "Google assistant? ALL2: co si myslite o prepojeni s IFTT alebo facebook botom (teda priamo botovi napisem na FB "aka je teplota v obyvacke" alebo "skontroluj zamknutie dveri")? Thx to all Y
